i have an SL320 which has problems with the engine, it goes in to safe mode at high revs, the diagnosis machines says that it is three injectors, would anyone know what would be the best way forward
yes, it is the V6, any suggestions as to what it could be, im really struggling, just replaced the gearbox which cost a fortune, its burning a hole in an already burned pocket!!!
initially it is fine, and if you was to drive with a very calm foot it would be ok, however as soon as you try and accelerate a bit more, the engine will go quite shaky and you would be unable to accelerate. once the engine is switched off and restarted it will be ok again.
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
