Problems with warning lights etc
DavePrentice
Glasgow
C230K 2002
I have a 52 plate C230 auto. Warning lights are on for ESP,BAS and SRS. I have checked front fuses (main box & side) and all appears to be fine. It is also stuck in P -although the AA mechanicic showed me how to free using screwdriver and lifting the coin holder until fixed. Any help would be much appreciated and wonder if the two problems are related.
Change the brake lamp switch that sits on the brake pedal, about £12 and easy to do, you will have to remove the kick panel to get to it :D:D
D
DavePrentice
Glasgow
C230K 2002
Electrical Problems
Many thanks for the advice. Also noticed a warning that a rear brake light is out also. Is this also why gear is stuck in P?
Yes the brake lamp switch can kill the speed signal in the BAS ECU, a very common fault
brandwooddixon
Wolverhampton
S63 Coupe 2014
... and the solenoid doesn't release the gearlever lock unless it detects that your foot is on the brake pedal.
