I wanted to add my experiences with retrofitting an APS30 to my W210, but the threads in which I found all the info are locked. I found the advice on this forum absolutely invaluable when it came to do the job, so here's what I found out about programming the cluster to display the Nav information:
I spoke with the guys at Whitefield Mercedes, Manchester, today (0161 796 1006) as my local dealership were not too sure if my W210 could be re-programmed to "see" my retrofitted APS30. I got the Whitefield steer from a link to another forum. They were very helpful and happy to give advice - excellent!
In an nutshell, yes the cluster can be re-programmed to show the Nav information because the 4716 APS30 has a B2B bus. Hook up the malfunction diagnostic computer and tell the car to look for the "Navigation" page rather than "APS30" (which it will not see - ain't there, apparently). I was advised that the whole process is very simple and should be charged at no more than 0.3 hrs (if at all!!!!).
I'm going to give this a whirl in the next couple of months when my E320 CDI W210 is in for a service and will edit this info if I find anything elso out.
Cheers
Jon
Cheers
Jon
