prop shaft bearings
N
nigelbunt
can any one advise me on the above. had it into garage with a clicking noise from underneath.told its prop shaft bearings. is it doable as a diyer or is it complex.:
And welcome from me, what is the car please
N
nigelbunt
hi to you. its a c class kompressor and a bad one at that. had gear box, power steering hand brake problems to mention just a few.
Well the link that jamessc put up is for your very car, a, few bits to remove, but do able
N
nigelbunt
ok.thanks for taking time to advise.wish me luck.......
If it is any help I can send you the official papers for doing the job
N
nigelbunt
yes please, if its no trouble.want to get as much info before i tackle job
5 pages sent, should cover it all
muller1
I live near Turriff in Aberdeenshire.
ML 270 Cdi and S type Jag 2.7 Diesel Sport Saloon, and now a VW diesel GT golf
Prop shaft
Did they say if it was the support bearing or the universal joint bearings. I think the support bearings would possibly have more of a growl/grind kind of noise and the uj bearings would have a clonk when starting to turn or take up the drive.
Try turning by hand and you will easily tell, there should be no movement at the uj /spider bearing but if it is the support bearing there will be a bit of axial movement which will not show up on the uj.
Mike
