prop uj donut.
lowrider
hi as it says. got to do a prop uj or donut on a 300se auto 1987, how hard or special tools needed for this job. help please.
Ian B Walker
Lancashire
300td
Which end, dif or gearbox?
Dif end, easy, undo center bearing then the 6 bolts on the doughnut, large old screwdriver and prise off dif.
Gearbox end, support gearbox, take off gearbox support, undo 6 bolts on doughnut, prise off as above. Please use new bolts when fitting new one.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Just a note about prop doughnuts: they're supplied with a compression strap round the outside and you're meant to remove the strap after fitting
If you don't remove it, what happens is this: you drive off and 10 minutes later there's a "Sproing! tinkle clank" noise and you screech to a halt thinking the worst. When you find the strap 20 feet behind the car a sickly grin spreads across your face
This "happened to a friend", obviously, and not to me
Nick Froome
www.w124.co.uk
L
lowrider
Hi, cheers for the replys. will report on wednesday.
eric242340
Banned
China
Nick Froome
www.w124.co.uk
Just for your info, they dont come with straps anymore, and fitting is a little fiddly but not impossible.
