question Diesel or Petrol
Discussion in 'General Mercedes-Benz Related Discussion' started by Royston59, Dec 19, 2012.
  1. Royston59
    Royston59 Senior Member
    632
    Feb 16, 2011
    Surrey
    Your Mercedes:
    2014 CLS 350 CDI AMG Sport & 2014 C220 CDI AMG Sport edition (Wifeys)
    I know its been done to death but its always a facinating topic for the answers it throws up........
    Do Diesel engines out last Petrol engines and (if so) why?
    We are not talking specifics here eg machinery in a commercial sense, simply Cars in general...
    Cheers
    R
  2. whitenemesis
    whitenemesis Senior Member
    17,978
    22
    Dec 21, 2006
    Your Mercedes:
    CLS55 AMG '05
  3. OP
    Royston59
    632
    Feb 16, 2011
    Surrey
    Your Mercedes:
    ah now there's a thought....I guess it must be mileage as I have seen a lot of engines out last the car that surrounds them...:D
    Cheers
  4. peterwhayward
    peterwhayward Senior Member
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    E240 classic est 2000 2.4
    without a real study done by any body of people its a difficult question to answer. i would think that most peoples perception is that diesels do last longer, but.......................that would only be the case if both cars were driven in the manner that they were intended with equal care given to both in terms of servicing etc. In real terms if the above was the case I would think that the diesel would do more miles if used for sustained distances (as intended), but last longer?, i'm not so sure.
  5. st4
    st4 Banned
    8,624
    Apr 6, 2008
    Sunny Scotland
    Your Mercedes:
    Disqualified driver
    Generally a diesel will tend to outlast a petrol but it depends engine by engine
  6. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    I am sure there is no difference in the 2 mileage wise, there is no reason for them to be any different from each other, technically the petrols should win as the diesels run with a higher compression
  7. Silver_Star
    Silver_Star Senior Member
    2,294
    8
    Apr 20, 2009
    Rural Leicestershire near where Pork Pies and Stil
    Your Mercedes:
    W203.006, S211.208 Land Rover 90
    But diesels don't rev as high therefore less wear will occur, particularly when cruising.
  8. television
    164,074
    310
    Your Mercedes:
    Debatable as thrust can cause more wear and my CL500 cruises at 70 at just under 2k rpm
  9. S80
    S80 Senior Member
    349
    Mar 14, 2007
    Sandy, Bedfordshire
    Your Mercedes:
    W124 280E '93 Volvo S80 Renault Megane Nissan Terrano
    Just a quick search on autotrader.co.uk for cars over 10 years old reveals:
    3854 diesel
    21873 petrol
  10. GeeAy
    GeeAy Senior Member
    131
    7
    Nov 27, 2012
    Notts
    Your Mercedes:
    2016 W205 C220 SE Exec
    I'm not a an automotive engineer, but my feeling is there are a number of areas which lead to an Oil burner being more robust. Firstly the componants are built like brick outhouses to contain the pressure required to combust and the pressure generated as BMEP (Break Mean Effiective Pressure which relates to the motive force generated). Secondly the high BMEP means the engine runs at significantly lower revs thus reciprocating wear over time is reduced. or something like that. But lower revs and stronger components probably covers it.
  11. peterwhayward
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    Thats because nobody sells a diesel thats just been run in.....where as petrol, they all want to get rid of.;)
  12. Silver_Star
    2,294
    8
    Apr 20, 2009
    Your Mercedes:
    Diesel is an oil, where as petrol is a solvent, which must have an effect on longevity. Diesel also has a lower combustion temperature.
    In reality in modern cars, the engine will still be ticking when the rest of the car is ready for the scrappy.
  13. S80
    S80 Senior Member
    349
    Mar 14, 2007
    Sandy, Bedfordshire
    Your Mercedes:
    Or alternatively because the high cost of diesel ancillary failures is enough to write off an older car?
  14. Silver_Star
    2,294
    8
    Apr 20, 2009
    Your Mercedes:
    Let's not forget diesel wasn't as common 10+ years ago. They didn't used to put the power out they do now in comparison.
  15. GeeAy
    GeeAy Senior Member
    131
    7
    Nov 27, 2012
    Notts
    Your Mercedes:
    Or they rattle so badly from new that you dont realise they've been knackered for the last 100k so keep driving it..
  16. S80
    S80 Senior Member
    349
    Mar 14, 2007
    Sandy, Bedfordshire
    Your Mercedes:
    So were probably more reliable ;)
  17. Silver_Star
    2,294
    8
    Apr 20, 2009
    Your Mercedes:
    Without a doubt they were more reliable.....but were talking about longevity here ;)
  18. television
    164,074
    310
    Your Mercedes:
    And at what cost, port motors, flaps, DPF's pumps, injectors, compressors, they are not like the old simple 603 engines, they can cost a lot of money to keep them going
  19. television
    164,074
    310
    Your Mercedes:
    And the horrible smell to go with the noise ;):D
  20. Sue new MB owner!!
    Sue new MB owner!! Senior Member
    160
    Oct 7, 2012
    Manchester UK
    Your Mercedes:
    SLK 200 /2009 /1.8
    I think Diesels sound like Taxi's .... nowt wrong with Taxi's ... but...
    Petrol engines just.... welll... sound better!!! ..... sorry no tech blah blah from me!! :D
Share This Page
