Question > Rough idea of cost ?
TILTNTURN
CLK 200
Hello .
2014 e Class Coup e requires NSF lower suspension arm replaced .
Was planning on getting both sides done .
Any rough idea of cost for both through local garage, labour/parts ?
Regards Tilt .
JBell
Torquey
C350 CDi Estate (GAD Edition)
Which Arm? There are 2 lower arms (front and rear)
Front is around £125
Rear is around £75
Get Lemforder parts (They are the OEM ones) ECP are a good source of them
You only need to replace the one that needs replacing, do the other one when it goes.
Labour wise about an hour per side
TILTNTURN
TILTNTURN
CLK 200
Rear is around £75
Get Lemforder parts (They are the OEM ones) ECM are a good source of them
NSF lower arm J . Thanks for the info
Tel: 020 8863 9233
