R107 Blue smoke on acceleration - MoT fail?
shakeel
The Highlands
E320cdi estate 2000 model
3 litre 1988 model 109,000 miles just failed it's MoT due to blue smoke on acceleration.
Is there an interim solution to get me through the MoT, like Forte engine oil additive?
I understand that my valve stems may need replacing, and the valve guides.
However I'd prefer to do the job in a couple of months time when I have more cash.
Any ideas most welcome
teddycatkin
cheshire cheese country
Did it only fail the emmission test then ? (Smoke is not an MOT listed failure).
If so then give it a good dose of injector cleaner take it on a good long run to get it nice and hot and run the test again --(remember you only have 10 days for the re-test) it should pass.
Alex M Grieve
Broom, Warwickshire
It is not uncommon to attribute sophisticated diagnoses to simple problems, and you may well be correct about the valve stems and guides. But it is not a particularly high mileage car. I would be inclined to take it out on the open road and treat it to an "Italian tune up" - let it clear it's lungs.
If the car does not do many miles, or does not get opened out that often, you may well find it will respond to a good blast. I don't think there is any downside to giving it a try.
star
Reading
Smart + others :)
Apart from 3 points if you get caught, :(. Milage or the lack of does not effect valve seals, they just harden with age.
shakeel
The Highlands
Thanks for that - I'll give both the additive and the Italian de-choke a try tomorrow
Smoke on acceleration is ring or bores, smoke after sitting at traffic lights and pulling away is valves
Alex Crow
Super Suffolk
and let us not forget the possibility of a split diaphram in the gearbox modulator.
do the gearbox changes 'bang' at all?
kth286
E320 Coupe 95
on that generation of car it will, as the oil gets into the vacuum pipes and then into engine.
shakeel
The Highlands
Thanks all, so far have done the italian tune-up and added Wynn's additive to engine oil to reduce smokey emissions. Both have helped a lot, and the exhaust oily smell is far less now than a couple of days ago.
However, I do have a little blue smoke after sitting at traffic lights, as Malcolm mentioned, which suggests valves.
And my gearchanges do bang a bit, as Alexander mentioned. Where and how do I examine a split diaphram in the gearbox modulator? Or can I examine the vacuum tubes you mentioned, and search for oily deposits there?
It seems quite feasible that I could have an engine valve issue and a split diaphragm in my gearbox modulator.
Any idea as to next steps?
Thanks again for your suggestions
Alex Crow
Super Suffolk
Are you saying a split gear change diaphragm could cause a smoke cloud to be emitted?
yes, and it can give you a serious amount of smoke, think batman or whacky races.
Alex Crow
Super Suffolk
sorry DM, i did think it odd that you did not!
m.mycat
There is a parts kit 111 here
m.mycat
shakeel
The Highlands
Thanks all, the car passed her MoT today.
So, I have the reprieve I wanted before examining valves and gearbox modulator diaphragm.
Thanks everyone for helping me through this one
