Paul Bee777
- Jan 23, 2021
- R129/1991/500
Hi guys, I’m new to the forum but I’ve owned my 1991 500SL for about 10 years and I’ve got an issue that I can’t fix which I’m hoping somebody might be able to assist with. Basically the AC compressor is continuously engaged unless I pull the fuse that powers it....in which case the clutch disengages immediately. This means that the after about 30 minutes driving the condenser ices up and blocks air entry to the heating system....which isn’t ideal! I’ve installed an “interrupter” switch in the car which operates across the fuse to switch the compressor off as a “fix” but I can’t work out what’s causing the problem. I’ve replaced the interior air temp sensors by the air intake and the one in the mirror, the heater control panel, and even swapped the NAS unit but unless I mechanically wedge the Siemens relay in the NAS open (opened the NAS unit so I could check the relay wasn’t arced closed...but it seems to work fine) when you start the car the relay operates and the compressor remains engaged even with the EC switch on, the blower off etc etc. It’s doing my head in....any ideas? Thanks
