Hi
i drove my 1995 SL320 yesterday and the heater only blows cold air, the day before everything was fine?
The control unit, temperature selector seams to work and light up etc, is there a fuse?
Tried the car again today, cold air only. However after about 5 miles down the motorway i turned the heater on again and heat came as it should?
something stuck or a loose connection?
Hi
mine was blowing cold air out regardless of the temp. selected, however the fan speed/volume of air was working (the same in both footwells). When i bought the car i was told the a/c didn't work and due to the weather i have never tried it.
How soon should warm air start to come through? not had the car long but i recall previously getting warm air very quickly from a cold start?
Hi
i have tried to access the self check on the heater control but i can't seam to get it to work. My car is a 1995 sl320 and has the push button panel with the digital temp in the top left corner. I have turned the ignition on and pressed the 'rest' button for over 6 seconds, but the display dosen't alter from the selected temp? am i doing this right?
The original problem is previously the heater kicked in with warm air after a very short drive from cold, now it takes ages or not at all (temp guage on 80 and still cold) ?
thanks
hi
thanks for your help guys, however i am still struggling tolocate the thing!
Is it the drivers side on uk cars (the picture shows lhd)?
i have the covers off from beneath the dash on the drivers side but can't find the sensor, is it near the footbrake?
thanks
Peter Best Insurance is a leading specialist in Mercedes-Benz insurance. All MBO members are eligible for exclusive rates on all our classic car policies. Call now for our 'BEST' quote. Tel: 01376 573033
