Chris Taylor
- Mar 30, 2020
- R129 SL 280 Silver With black interior
Coffin module is passenger side under the plastic cover in front of the windscreen - where the ECUs are hidden in a big metal box. From memory there are 3 screws holding the cover down. Bear in mind that's on my 93 500 so yours may be different.
That white tube from memory goes to the coffin module which also has vacuum supplied from a take off to the inlet manifold. It may be worth blanking that pipe off to verify no issues with the one way valve in the manifold drawing vacuum back via the inlet manifold.
Thanks.
I will have another look when I get the chance later.
That will be the same place as my diagnostic port.
