Top Cat 500
- Apr 11, 2012
- Location
- Newcastle upon Tyne
- SL500 1999 : GLA220 AMG 2014 4matic
I cant find a thread with a similar problem, so has anyone ideas about this one?
Instrument cluster suddenly failed except for clock and dash lights
Fuse 10 blown "Instrument cluster"
Checked OBD codes (the were none a few weeks ago) - it returned
P1741
CAN signal from ETC
Checked MB Fault code manual (1999 R129 5.0, 113 engine)
'CAN signal failure from ETC or Instrument cluster faulty'
which was not a lot of help!
CAN - I think this is the main data bus
ETC - I think this is Electronic Transmission Control
To work out which it was (in case the instrument cluster fault was simply the blown fuse) I did the following:
Cleared the fault code
Restarted without the fuse - rescanned and the code did not appear, so the fault was not the blown fuse
Replaced fuse, everything appeared to work, rescanned and code did not reappear
Started test drive, put foot on brake pedal, then removed it, and the fuse blew and the code reappeared.
What should I look at now?
P1741
CAN signal from ETC
