R129 no bass from speakers
r129co
Kent
r129.co
R129 SL500
I have a 1996 SL320....it does not have a Bose system.
there is no response from the main speakers in either door..just the tweeters.
I have tried different Becker amps under the rear seat and it makes no difference...it also makes no difference unplugging the amp or plugging it in.
Any ideas?
Robbostanhill
Dartford, Kent, UK
E270 Estate 2003 and *Her* C220 W203
Naturally you've tried setting the bass on the radio etc ?
Using a small battery (Penlight cell or button type) make a link wire from the battery and "flash" the terminals on the speakers. This should give you a sound from them as you do it. Don't use anything heavier voltage as it may destroy them entirely. If they work and make noise then work back to the connection at the amp, using the same process see if the speakers make a noise. If they do then they are fine and the cables are connecting.
r129co
r129co
Kent
r129.co
R129 SL500
Will do...wonder why they both have failed tho?
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Pull the speakers out and check them with a voltmeter. They should be around 4 Ohms. If they are o/c they're blown
They've probably been overdriven and have popped
Nick Froome
r129co
r129co
Kent
r129.co
R129 SL500
Merci
later 129 speakers are all 1 ohm, if you use too high an impedance the sound output will be much reduced. they cost £100 each from MB
r129co
r129co
Kent
r129.co
R129 SL500
Ah thanks...are you a new boy Television..haven't seen you in these parts for a while!
Yes a newbie as from yesterday
You can test a speaker for good/ bad with a 1.5 volt battery, with the battery in one direction the cone will move forward and in the other it will move back.
Do not do this with tweeters though.
r129co
r129co
Kent
r129.co
R129 SL500
Solid as ever
www.ckinsurance.co.uk
