transcup
Recently bought 1998 R129 had panoramic roof on until last week.New Softop been fitted at some stage. Not used much, looks very new.
Roof goes down perfectly and everything including windows up ect OK.
When you put roof back up everything Ok until rear section goes down into holes ,it goes down into clamps and you can here it pulling down and looks OK, windows start to go up , go to top then go down again and rear section starts to go up and down, trying to reseat again starting that sequence.
If I release red button before windows go fully up light goes out , then drivers window manually up , still out , but as I put passenger window light comes on and stays on , when you move bongs go off.
If I keep quickly pressing red button it eventually stays out and its OK
I suspect its a micro switch or something not seating correctly
Advise needed please
Can you help
If it goes to an indepenedent will the computer show what the problem is?
Steve
Can you help
Steve
