R170 2001 SLK DOOR REMOVAL PROCEDURE
vauxhallmaniac
SL350/SLK320 Special Edt/SLK320 "Tinkerbelle Edition"
Hi All, need some WIZ instructions to remove the doors for the SLK repaint!! cant decide wether to unbolt the hinge from the pillar or off the door & is there a multiplug for the door wiring loom or unplug everything and pull the loom??? thanks Simon...:D
You take out the bolts from A pillar, and the stay, disconnect the mirror and door control wires then pull them out as you remove the door
V
vauxhallmaniac
Thanks Malcolm much appreciated :D:D
