John77
- Nov 19, 2018
- E200 Estate 2011, 2009 SLK 200
Sun Visor Lights do not work. There are two electric connector on the roof clip and two little connectors on the sun visor arm. See photos. Well if I put a wire across the tow connectors on the clip, the light comes on. If I put a continuity test on the electrodes on the arm there is nothing. So I take it that there must be a connection between the two visor arm connectors inside the are that has failed. I think that if I solder a small wire between the two visor arm electrodes it will work again. What do you think?
