R230 Alarm 'Beep'
ajlsl600
france
The "beep on my sl was not loud at all. Just enough to be aware from 20 mètres when locking car. That thing has internal batt the Benz organize to leak all over pcb. It's 100 to replace.. No??
McDonald
Surrey
SL500 2004
The "beep on my sl was not load at all. Just enough to be aware from 20 mètres when locking car. That thing has internal batt the Benz organize to leak all over pcb. It's 100 to replace.. No??
I imagine you made a noise louder than the siren when that fault revealed itself. It's vexing to find silly design faults in a fine machine.
Oldcodger
Oldcodger
SL500/03, GLC/19, Smart EQ Fortwo/69
  • #25
Ah this is a new development - there's a battery somewhere?
My old Saab 95 had one stuck under the wheel arch which was a right bugger to get to but was cheap to buy
flowrider
SL500 (R230)
The battery is in the siren.
EmilysDad
Bury Lancs
ML350
If it's any consolation, the battery in Vauxhall's 'power sounder' will leak too ... they've been known to start a fire too
ajlsl600
france
Understood. But, with little effort these could have had batteries that were replaceable and designed such that the defective version did Not leak all over the pcb.... Another Dtf in fact I think it should be MBDTF 500 not MB 500. Sure other makers similar.
Oldcodger
Oldcodger
  • #30
Where is it exactly?
ajlsl600
france
In the rear part of p/s front wing. On r230 vdoz anyway.
Oldcodger
Oldcodger
  • #32
Fairly inaccessible then?
That figures - stops easy tampering but makes for expensive replacement
Oldcodger
Oldcodger
  • #33
Update - tested the alarm and whilst the indicators flash rapidly there is no other alarm
So the sounder battery is a goner then?
ajlsl600
france
Almost certainly. About an hr at home job. Loose wheel jack up, liner out. Think 10mmspanner socket job and one plug, memory not great but that's about it. It's the £100 that hurts, just so you hear a beep on locking, if it gets nicked those guys will know how to disable it, keyless go towing switch or even alarm off switch.
Oldcodger
Oldcodger
  • #35
Is that not the alarm siren then? I get no sound at all when alarm is triggered.
No siren , no horn nothing
If it was just the beep wouldn't bother
Thanks for response
flowrider
SL500 (R230)
Thanks for response
The locking beep is from the siren.
Oldcodger
Oldcodger
  • #38
Had a look today and there doesnt appear to be an option to disable the beep.
I could always send you my siren when I replace it?
That doesn't make any kind of sound!
:D:D
Uncle Benz
West Sussex
Mainly Mercedes
If you buy a new siren from Merc 99/100 it is set to Europe, and will beep three times for lock and once for unlock. You'll need Star to switch it to uk, and no beep.
www.W140.co.uk&www.r129.co
