- Aug 25, 2006
- Location
- Midlands / Charente-Maritime
- '93 500SL-32, '01 W210 Estate E240 (RIP), 02 R230 SL500, 04 Smart Roadster Coupe, 11 R350CDi
Great stuff! Just plug on through it all and you'll get there!ok . eventualy found out that puling the drain panel from the end and up .almost to the point of breaking it and it came out . for info there is a lip that enters down into a very tight slot at base of screen as oppossed to a u shape channel that is a push fit on the end of the glass i will get around to posting a picture, had that been the case on WIS i would have had the thing out yeserday
anyway found and fixed so far
B1467 M16/32 heat exchanger shut off valve
B1341 alarm horn
B1639 coolant level s41 and s42
I am waiting camera to have a further good look around then i will hook up battery and see suspect/hope some other faults are voltage low related. seen nothing specific on ABC as yet but have yet to work on check power at ABC MODULE tho i know it showed up on last quick test , access to anything is without a doubt,a ballache .
CAN lines all go to the EIS from memory.
I bet Lovelys name is mud.....
How are you getting on with it Andy?
Cool - I'm definitely still on for the 17th/18th. I arrive quite early so if you need a hand I can help out if you want.20 k today ,no malfunction on dash !! on star i dont have any abc issues or sbc comms issues ,i have an interior can issue in quick test to find ?? but everything works , cleaned loads of connections . .i sure know a lot more ,been on it for three weeks in between other jobs , broke 2 clips, spent 250 euro on clips, sensor x 2 and under bonnet sound proofing... will run it around for a few days then quick test again , what a bitch ,everything is to get off,out !!! lower screen plastic panel !!. still dont have grille out , followed wis , sure it will break , hindsight says secret is DONT rush . still looking ,correct 2 pin plug for rear abc lock valve , not exactly happy with soldered repair . still on for end of month ? rain ,clk sun SL BIG smiles this pm tho..
Ferry gets in about 7am at Caen from memory but don't worry I won't pop round that early!
I thought I might take the chance to see a few bits and bobs before heading over.
Probably just after unless you need a hand with anything?
