R230 Parktronic Stray Connector?
Lowe712131
Midlands, UK
R230 SL500 / Aston Martin DB9 Volante
I stripped the boot lining out of my SL55 on Sunday to try and get to the bottom of the Parktronic not working (never has since I had the car - it just alarms with all lights on, then switches itself off). A STAR readout showed faults on nearly all the sensors, which to me says ECU rather than a sensor issue, they are all clean with no damage etc.. Located the ECU in the boot, took connectors off, inspected for dry joints etc, cleaned and reattached but still got fault. One thing that did strike me though, there was a 6 wire multiplug just hanging loose in that area, not connected to anything (See pic) . There are no spare connections on any of the ECU's in that area, however I did notice a spare socket that looked suspiciously like it might fit it, on a short length of cable going through a grommet into the rear wing area (Second pic) , although it seemed to far away from the plug to reach. Does anyone know what this multiplug is for? Wire colours are :-
White/Yellow
Brown/Blue
Black/Yellow
Yellow/Red
Yellow/Purple
Yellow/White
Is this something to do with the Parktronic maybe? The socket that looks a possibility goes through a grommet into the rear wing area, under where the aerial is. I didn't want to try tease the cables together and connect them without knowing it's definitely the correct connector first! (visions of towering inferno and hysterically cackling insurance man!)
PIC 1 : https://www.dropbox.com/s/b9zwa2396f548nz/IMG_0305.JPG
PIC 2 : https://www.dropbox.com/s/wcmofqon5yx16rq/Pic%202.JPG
Many thanks
Simon
drmw
Yorkshire
www.autonomed.co.uk
I would have said you've cracked it until I re-read the opening line - if it was something as fundamental as the plug has fallen out, I would have thought star would show all sensors as opposed to nearly all
L
Lowe712131
Midlands, UK
Thanks for that - I think it was all the rears showing faults, and most of the fronts (from memory) - will have to dig out the printout - it might even have been all of them to be honest, will check. The socket looked as though it has not been connected for some time. I've left it all in bits anyway, so will give it a clean up and check voltages on it etc..
I will give it a go later in the day to see if I can find what that plug is.
AdamG
Bromley, Kent
S320CDI (2003)
Those connectors look very similar to the w220 rear parking harness.
When I retrofitted parktronic I found that the system needed a complete set of sensors front and rear or it would flag a fault for all of them. I only discovered this after buying a replacement ecu :Oops:
The question has to be asked though why have the sensors been disconnected?
Adam
vauxhallmaniac
SL350/SLK320 Special Edt/SLK320 "Tinkerbelle Edition"
That is plug X35/28 PARKTRONIC WIRING :grin::grin::grin::grin:
L
Lowe712131
Midlands, UK
Thanks for the replies, that's looking promising then!
Maybe it was disconnected deliberately to mask a problem, however the connectors are a bit too far apart to fit at the minute, so I can't help wondering if the bumper has been removed at some point in the past and the socket wiring has been pulled through the grommet slightly, disconnecting it. Will clean and reconnect it and have a look ..... fingers crossed!
Cheers
L
Lowe712131
Midlands, UK
We have a winner!
All sorted! Thanks to everyone for the help - gave the socket cable a gentle pull and sure enough it come back through the grommet, long enough to reach the plug. A quick clean up and a spray of non drying switch cleaner and it's now 100% working for the first time since I've had the car! Nice one :)
Simon
Tel: 020 8863 9233
