- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
I also suspect the C Pillar seals are leaky too but am not sure exactly which bit is the C Pillar?
C pillars are the metal sides to the rear window, water can run down the outside of the rubber seal at the bottom, and up the other side into the boot, usually landing up on the side of a load carrier. Most of the trouble here is where the is not sealed to the metal on the inside, by starting to open the roof and stop when the boot lid is open backwards they are facing you, and a matter of cleaning out any moss or rubbish and sealing the rubber all the way along as far as you can with the Loctite. It does not matter if it looks messy as no one can ever see it.
