Motozone
- Nov 18, 2015
- Location
- Gatwick
- R230 SL500 2004, W639 Vito Dual 113cdi 2011
Morning all, my boot release more often than not will not quite release the boot. There is a sound about half a second which I guess is the release/close mech in action. The boot is not the power open type, I guess the springiness of the seals makes it pop-up or release. New gas struts fitted but these only take effect once past half open. I usually have to use the catch which works fine, it feels like I am only moving the catch a small amount to release. This being after using either the fob or door release.
The car does have Keyless Go (none of which works) although I can't see any relevance.
The self close system works well with about a second or two of pump? noise.
The boot seems correctly aligned when closed.
Is it a case of adjusting the release bracket a touch? Lubrication? Or is there a mechanical solution within the lock mech in the lid itself?
The lock and its catch seem free and not worn at all where visible.
Had a trawl but did not find an existing answer.
