Orb the Impaler
- Sep 18, 2008
- Location
- Lancashire
- SL350 R230 Gen 3 | SLK350 R171 | C200 CDi Estate S204 | Yamaha R1 2CR | Yamaha Tenere 700
First of all - hello! I'm new to this forum. I've recently graduated to a 2002 SL500 from a SLK230 and Mrs Orb(s) has a C220 CDi Panorama Evo
I hope it's not bad form to post a question as a first post.....
I've noticed a couple of odd things about my SL. First of all there is a clicking noise coming from the boot/trunk from the region of the consumer battery (it could be the battery cutoff relay). Basically it goes "click-click....~10 second gap ... click-click etc" It seems to do this for around half an hour and then stops. While it's doing this I've noticed that the CD changer (in compartment behind left hand seat) makes a small click-whirr. If I jack out the cd cart the little green "eject" button flickers. This happens on every second "click-click". Does this sound even remotely normal? I suspect not.
Next up: when the car is stopped there is a noise coming from the little vents between the left and right temperature knobs (below the Comand unit). I can best describe it as a constant, low "rrrrrrrr" noise (sort of like a car purring). I'm not sure but I think I can also detect a faint bit of air blowing - however it's hard to say. This seems to carry on all the time the car is stopped. Can any other R230 owners tell me if this is normal either?
Any help appreciated. Especially if it doesn't involve spending thousands down at the MB dealer for their fitters to take random guesses and replace all the electronic boxes!
