R230 SRS light and link error..
Conor
London, UK
Howdy guys,
Was a rare sunny day in Ireland today with dry roads.. I decided to take the R230 out for a spin.
As usual, when I fired her up, secondary battery was low, so "consumers offline..." message appeared for a while. This is normal and usually goes away, but...
This time the SRS light persisted. I drove for a while and restarted the car to no avail.
Trying to connect to that module on my iCarsoft MB V2.0 shows a link error, prompting me to check connection, car turned on etc. I can access other modules.
I wonder is it a voltage thing and need the car to charge a bit more, or is the SRS module bust?
Where is it located? The boot has been getting a bit damp lately from condensation (not leak)..
Anybody familiar with this?
Thanks a lot.
EDIT: I'll dig out STAR and see if that can give a more specific message.
Uncle Benz
West Sussex
Mainly Mercedes
It’s bolted to the transmission tunnel, just in front of the gear selector
Conor
Conor
London, UK
Sounds like a delightful way to spend a day, heh!? You suggesting it needs replacing then? Booo!
Uncle Benz
West Sussex
Mainly Mercedes
If there are no comms check with Star, (other machines have been known not to work…). If still no comms, check for power and earth at the plug on the module
Conor
Conor
London, UK
Ahh couldn't get in via STAR there now. It gave a link error too.
It suggested the usual issues but one possible fix suggested was a module reset which included removing fuse.
I'll have a look at that again as it was cold outside.
I am inclined to think (hope) The module isn't completely bust as the battery was quite low after not being driven for a month.... that will teach me!
Timeandleisure
London
SL500 2003 R230, E400d 4MATIC Coupe 2021
I used to have that issue and just asked the dealership to clear it down during its MOT and it never reappeared even when my consumables often went offline...
Conor
Conor
London, UK
Did you jump start it?
Nope. In fact the primary battery has never let me down since buying the car. Always starts on the button. I think I'll throw the secondary battery on trickle charge now and come back to it later and see if it makes a change.
I'll also try the reset feature as outlined by STAR
Conor
Conor
London, UK
Oh cool.. that sounds promising.. I will spend more time on STAR in the coming days and see what I can come up with.
Uncle Benz
West Sussex
Mainly Mercedes
Didn’t think you were that green ;)
Conor
Conor
London, UK
Is it bad to jump start ? What am I missing that might be good to know ?
Uncle Benz
West Sussex
Mainly Mercedes
I’ve just seen a few horrors over the years with blown modules. If you must, use a good quality jump pack with a surge arrestor in it. Jump leads are not recommended
SL63 Mark
The South
R231 SL63 AMG
I had the dreaded SRS warning light, it's an MOT fail in the UK, so not something you can ignore. Seems like I've had most problems that come up on here :(
Anyhoo, STAR said it was faulty passenger seat buckle, so we replaced that, re-set the SRS light on STAR, but sure enough the light came back on as I drove home.
So I went back to the dealership who re-set it again, and the light came on again, but after a while it went off and stayed off.
So what I am saying is, the STAR re-set process sometimes takes a while to work, for some reason.
Good luck with getting yours sorted, Conor
Conor
Conor
London, UK
Delightful... so i'll be keeping this thing on tender from now and bracing myself for some tedious troubleshooting.
I'll keep you guys posted.
Thanks a lot guys.
Timeandleisure
London
I know I have come across the warning not to jump start the SL500 somewhere in the accompanying technical docs, so I have tried to avoid that.. but it's probably to safeguard those, like me, that don't have much experience.... :geek:
I know this has probably been posted before, but I found this technical material online which has some useful information on the dual battery system if anybody is curious about the finder details.
Missing an attachment?
Conor
Conor
London, UK
  • #19
@Uncle Benz on the off chance... is there anything in the boot that could cause this if wet?
Uncle Benz
West Sussex
Mainly Mercedes
Hmm, if you had multiple modules that won’t communicate I’d check battery voltage as a first thing. Battery control unit is in the boot. I’m assuming everything else is talking? If battery voltage is good when engine running it’s unlikely to be that simple. I’d be trying a straightforward unplug and replug of the SRS control module first I think. I can’t think anything else in the boot would have a bearing on it. Check the battery connections are sound though.
