From the photo it looks to be the large one at the bottom, about 60-75mm in DiameterRCA918 said:Thanks.
I will double check the hose again.
Is there any hose connecttion beneath or on other side of Radiator not seen in this picture. Which hose do you believe is the suspect? Is it the rubber hose with metal spring around or the bigger hose (10X size approx)? What are the hose connection call by the way?
Kind regards
television said:We always used to smear a little grease around the inside of the pipe, but that idea is fround upon these days.
malcolm
Another good reason for me to go back to bed.Blobcat said:Silicone Grease would be ok as it would not rot the rubber.
Sorry to go a little off-track, but I read recently somewhere that any kind of silicone lubricant should never be used under the bonnet where there is a MAF sensor. Even gasket compound containing silicone is to be avoided as a miniscule amount of silicone contaminated air going into the intake will wreck the sensor apparently.Blobcat said:Silicone Grease would be ok as it would not rot the rubber.
tom7035 said:Sorry to go a little off-track, but I read recently somewhere that any kind of silicone lubricant should never be used under the bonnet where there is a MAF sensor. Even gasket compound containing silicone is to be avoided as a miniscule amount of silicone contaminated air going into the intake will wreck the sensor apparently.
For what it's worth.
