Andrew Rolland
Hi all.
The standard Merc radio in my finacee's 2003 C Class Coupe doesn't work properly.
You switch the thing on and you can listed to the radio fine, but when you start moving it looses the radio signal and it goes all static and you get interference. You come to a stop and the radio starts working again.
It is like the radio cannot track the radio signals when it is moving.
The CD player works fine.
I sounds like to me that it is a loose wire on the aerial feed to the radio but I'm not sure.
Does anyone have any suggestions?
Where is the radio aerial, windscreen or rear screen? How do I get the radio unit out of the dash to check the wiring?
Thanks in advance.
Andrew
Thanks in advance.
Andrew
