Hi all,
Have recently purchased a 2.0Ltr 190e and I'm looking to replace the thermostat as I have a suspicion that it is stuck open. My question comes from the fact that I cant seem to locate the engine block drain plug - the haynes manual say located on the right hand side (all I've found so far is the sump drain plug). So if I drain the radiator only, is it OK to mix the new antifreeze with what ever is left in the engine block. The reason I ask is that the new stuff from MB is a dark green/blue colour and after checking the coolant in that expansion tank it is a reddy/orange colour.
Many thanks
Adam
Many thanks
Adam
