Re-programming W203 key remote to central locking
scubacrazy
London, England
Hi all,
I have a 2001 (51 plate) C240 Elegance estate W203. Following a recent problem which resulted in my battery being disconnected for a while, I find that the remote keyfob does not operate the central locking any more. It does however operate the ignition fine. I can gain entry to the car by using the little "pull out" emergency metal key.
I have searched on the forums for advice on how to re_align the remote to the central locking, but it seems I cannot find the definitive answer to my car. Could some-one please advise me on the correct procedure please.
Thank you in advance, your help is genuinely appreciated.
Cole@MBS
www.mbssouthampton.co.uk
I think th RF part of the key is u/s, you might have to buy a new one!!
redhot.0121
birmingham
Hi all,
hi i only joined yesterday i to have a similiar problem with 230 elegance have been advised about a fuse in the boot os or a split in the vacum pump as my alarm went crazy and locked down my car.can still drive and manually open but not my boot if you can get in your boot try these two items if this is any good.malcom and mbtech gave advise also check batteries in fob?does the car still flash when fob is pressed
Ellsy Tanners
Mars
Its possible the rear sam has blown due to the battery been reconnected. It happends some times I am afraid.
Does the fuel gauge work when the cars running? Boot and tail lights work etc.
Have to be careful here as we have 2 totally different car system here.
I will post back
On the 203 I think that Ellsy is right here, it all goes through the rear SAM
On these cars they have both RF and IR and both would not fail at the same time other than the rear SAM going down
www.W140.co.uk&www.r129.co
