Re Tension system for fan belt 140 S350TD LHD
Status
Not open for further replies.
Robin Hillman
New Registration
It would appear that the mounting/bearing  has in someway failed and the small wheel is no longer in alignment with the other pulleys/wheels . You can clearly see rust  staining where the unit is attached to engine block.
Do I need to change the complete unit. ? or is their a bush or bearing in side  that must be changed?
Any help given would be greatly appreciated.
Status
