30471
This fails to work and my service guys are suggesting that the only remedy is to replace the rear windscreen.
Apparently a sign of a faulty windscreen is to see faint white smudges on the heat coils in the screen. There are none.
There is a current passing from the on-switch through the lead and on to the connection but my service guys feel this is low at 2 amps. Further advice has said that it is normal that this failure happens and at best the rear demister is slow - Any one had the similar problem ?
Can anyone assist in suggesting a remedy rather than the drastic solution so far provided.
