Rear diff oil change
S.Speed
Lancashire
Saab 9-3
Hi All,
Car is 2003 C270 CDI with 53k on it.
What sort of mileage would the gurus recommend changing the rear diff oil at?
And also what spec of oil is it I need assuming you suggest a change.
Thanks in advance,
S.Speed
S.Speed
Lancashire
Saab 9-3
Errr thanks for the response (I think)..
Is that a serious response?
Or is it out of the same drawer as the "in for life ATF" Lol??
Simon try washing out the washer tank,,they can get to smell horrible
S.Speed
S.Speed
Lancashire
Saab 9-3
Thanks Malcolm..
Again thats something I have never done.
My word all this stuff I am learning on here as I become enlightened and aware.. At the rate I am going I shall be almost knowlegeable soon !!:D:D
turbopete
Spennymoor
2010 '60' Ford Mondeo 2.0TDCi Zetec (sorry)
on a related subject, my diff has a leak from the pinion oil seal. not too bad but annoying. when i get the car back, i want to either sort it or at lleast top up the oil so should i use a forte seal conditioner (used successfully in a sierra for rear crank seal leak) in a diff? and what oil does the diff require? ordinary ep 85/90? 75/90? or something more specialist?
Diffs on these cars can look messy,,Hypoid oil foams when it gets hot,, you have a breather right on top and this should be kept clean,,this used to be a problem some years back when I first joined but hardly ever talked about these days
There are a few different setups and mods, but not easy things to change are the seals, early cars have vents at the ends
turbopete
Spennymoor
its definately the front seal (around the propshaft flange) and it has sprayed oil around on the floor of the car in that area (at least it shouldnt rust) i just wondered what oil it needs, if its just hypoid ep oil or special oil, and if it would be wise to put a forte seal conditioner in a diff or if its bst to just keep the oil topped up until it gets severe?
I am sure it was a 90 hypoid oil
My 210 did this, the breather became blocked and forced oil out of the seals, it didn't leak much just the occasional drip, I had the breather changed and the seals replaced. Having said that I think it would have run for many thousands of miles with no issue at all if I'd have left it.
turbopete
Spennymoor
thanks for that. its something less to worry myself about!
With Turo, you can book and drive any Mercedes you want, wherever you want it, from local hosts across the UK, US, Canada, and Germany. Test drive cars you otherwise might never get a chance to try, or hire something interesting for your next holiday:
www.turo.com
