Rear Door Lock
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Newspaperman, Dec 28, 2012.
  1. Newspaperman
    Newspaperman Member
    18
    Aug 14, 2011
    Clitheroe, Lancashire
    Your Mercedes:
    C320 AMG CDi Sport 06 Reg
    Just noticed the nearside rear passenger door lock does not operate when pressing the remote key any ideas (Actuator faulty???)
  2. OP
    Newspaperman
    Newspaperman Member
    18
    Aug 14, 2011
    Your Mercedes:
    If you manually open the door from inside it locks fine just wont open
  3. EmilysDad
    EmilysDad Senior Member
    9,232
    2,759
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    Probably.
    Does it even try to lock? Can you hear anything at all? On a previous car, it just needed a good lubricating on all the linkages inside the door to fix a similar problem. ;)
  4. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    They are electric motor driven locks on this car
  5. EmilysDad
    9,232
    2,759
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    They are on a Vauxhall too ;) ;) But if the linkages are tight, the motor tries, struggles & then gives up. :lol:
  6. television
    164,074
    310
    Your Mercedes:
    There used to be a problem on the early cars where the locking rod that passes through the inner door skin had a rubber grommet that was too tight at the top and this prevented the locking action.
Share This Page
