Manc Rick
- Jul 7, 2020
- Location
- Manchester
- W213 E220 Premium +, 2017 with OM654.
Hi all,
I’m well used to jacking up the car using the front central jack point and also the side skirt jack points, but I need to jack up the back in order to change the fuel filter (tried it with heavy duty trolley jack at the front but still not enough room to work under where the filter is at the back).
As far as I can see, the only possible option is the rear differential and I’d rather not do that (or is that quite a normal thing to do)?
Once the car is ‘up’, I can put stands at each side rear jack point (using the rubber adapters which I have).
What do other people do? Or don’t they?
