franksm
Hi folks
Summary: lamp has 12v with no bulb in; stick a bulb in, zero volts
Have a real oddball of a problem with the offside rear lamp cluster on my W124, specifically the tail-lamp. The brake/indicator/reverse lamps are fine, just the tail-lamp exhibits the problem:
For one thing it seems to get throught bulbs a bit more often than I'd like. It's possible that the bulb quality isn't great (Halfords brand) but... they work fine in other parts of the car.
The real problem is that the tail lamp now doesn't light up at all (even with known-good bulbs). The bulb-failure system lights up to confirm this. I take out the bulb, measure the voltage: a healthy 12 to 15 volts there. Put a bulb in, and it's zero volts. Totally repeatable, have never seen anything like it. The earth is all good there and like I say, the other bulbs work fine.
Could it be something screwy with the bulb monitoring system ?
I am using 10w bulbs there, as per the OEM application.
Frank
Frank
