DoctorGee
- Jan 26, 2008
- Location
- Greater Manchester
- 2002 S280, 1998 S280, 2004 ML 350
From what I hear this is a common problem with the W140. The power window has not worked since I aquired this S280 two months ago. I can hear a motor sound and clicking when I try the switch, but there is absolutely no movement in the window. The window also slides down gradually over days, so I have to keep pulling it up and holding it with black tape inside.. Do I need a new motor (seen 'em on ebay for £30..) or is it just some bearing worn out?
Also the other windows are often sticky when coming up. That improves if you don't totally depress the switches when you use them. Any ideas anyone?
Thanks,
Greg.
Thanks,
Greg.
