rear side window outer aluminium trim removal, any advice appreciated.. 280ce
Razor Burns
mercedes280ce 1979
I am just about to work on my 280ce specifically any advice on removal of aluminum outer trim rear side window without damage, tips, clues, screws n glues.. would be appreciated.
rifiki
Worksop
CLK W209 W121190B
I don't know if the 280CE is same, most cars peel back the door rubber underneath will be a crew/nut,the rest should be clips. May require special trim removal tool.
Razor Burns
Razor Burns
mercedes280ce 1979
a/ I don't know if the 280CE is same, most cars peel back the door rubber underneath will be a crew/nut,the rest should be clips. May require special trim removal tool.
q/ Interesting... as Its a coupe clearly no back door ?? do/did you mean window rubber ??
rifiki
Worksop
CLK W209 W121190B
Its the trim just under the windows. If it's the C shape trim, clips only?
Try Youtube or Haynes WS manual
