Rear view mirror removal 129 question
Pipemaster
East Midlands
SL350 R230 / 2006 / 3500
I want to replace the rear view mirror on the 2000 SL.
It is the manual dipping type so i dont thave to worry about power cables etc and I have the replacement part which seems to be a clip and clip type.
I am concerned about getting the old one off without damaging the trim on it or surrounding area. I undertsand there is a CD with video clips on it for perfomring certain procedures does anyone have this and if so can you tell me if it thas a clip of the removal procedure on it? If not can anyone advise me on the removal procedure
Thanks in advance
I will have a look later in the day
Ellsy Tanners
Mars
It simply pulls down, the to pins will be squeesed inwards and the mirror will drop, can take a great deal of force, same with puting it up, give it a good hard bang on the top and it will pop in.
Thank you, I remember now that when I was crawling up from underneath I bashed my head on mine and it fell off
Pipemaster
Pipemaster
East Midlands
mental image there successfully dispelled by Malcolm =0) !
Thanks for the advice I'll give it a go over the weekend..
Pipemaster
Pipemaster
East Midlands
easy job but stealers were wrong
With the knowledge that Malcoms head was enough to detatch the mirror I slid it off with a quick tug, no problem. Interesting arrangement the morror just clips into place using a captured spring loaded double ended bar.
So I unclipped the cover and revealed that the tilting mechanisim had simply come out of its locating lugs, I clipped it back in reassembled and all worked fine. The thing is that the stealers who said they had looked at it during a recent unrelated visit and it was beyond repair and it would be c £75 plus labour for a replacement. I suppose it is just another example of the replace instead of repair mentality which seems so common these days. :(
Again thanks for the advice it gave the detail I needed to do the job :D
www.W140.co.uk&www.r129.co
