Rear wheel arches, rust and a simple modification
  • #81
We had ours repaired at a body shop and the red matched up very well. To the point since then I have greased the inner ledges as the bodyshop said this was as good a way as any for keeping water out and preventing rust.
During the winter I will grease the inner ledges every 5-6 weeks. I suppose this is not as good as waxoil, but nevertheless a simple and cheap solution ?
Any comments ?
Yes grease is not waterproof, it will absorb moisture, pleas note, it is the lip of the arch that needs the plastic trim as it is the edge where rust starts and from the factory just no top coats on the inner lip or edge.
Petemac
Inverness
merc c250TD 99/2000 150000MILES ON CLOCK GREAT CAR
great post malcolm and mic CT1 is the bees knees did my caravan with it 2yrs ago 100% dry will be good for this job
SteveX
Good work, I cleaned all the gunk out of mine the other day and currently waiting for some dry weather or a chance to get her in the garage to waxoyl the inside lip.
Hippy
cambridgeshire
C Class
Great post, really concise, thank you I shall be following your advice!!
My father taught me to always start washing the car by starting with the lip around the wheel arch, that was 30 years ago!!!
tbh, I have been looking for an excuse to be "drooling" over the car.
Thanks again!!
DriverKavinsky
clk/2005/2.0
So many of our cars have this problem that I thought that a little DIY that I have done could help others, even if you do not have rust, most of it can be kept in check with a simple mod that will be in part 2
Hi, TV
Please could you tell me what paint you are using is it rustoleum, also where could I source it. Thanks!!:)
turbopete
Spennymoor
Hi, TV
as stated in your other post. the paint is HAMMERITE (brand name) and pretty much ANY DIY shop will stock it
-raj-
Coventry
Multiple R230's & E250 CDI
Thanks television did this mod to mine over the weekend. I used the rubber U channel below which turned out to fit great. I'll put the link up too if anyone wants to buy it, you will only need 2m :)
http://www.ebay.co.uk/itm/321177864301?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
David-Butter
Suffolk - East Anglia
www.sntuning.com
mercedes CLS 320CDI , landrover discovery 3.0 twin turbo and Ferrari F430 Scud
Brilliant job, sorry to raise this olden back up again, But I tried this with and w210 over this weekend following this advise.... Worked a treat :)
nokia
London
W211 E320 CDI Avantgarde
Is there a PDF of this around? THe pics seem to have gone from the first post.
Lit.91
GB
MB
Are there any chances of reviving the pics in the original post?
Parkgate
Notts
CLK 2005 2.7CDI
Made a start on the rear arches on my w209. Removing the arch liners was a pig but they had to be removed as there is no way I could scrape all the crud out (lots and I clean them out most weeks!) and there's no room to get behind the flange to treat its rear face with the liner in situ.
Took ages to clean to an acceptable level, then i treated with rust converter, twice, then three thick coats of Davids Zinc 182 on the inner face and over the edge of the flange. Made good use of a hairdryer to aid drying, then finally three or four coats of smooth hammerite, very messy stuff, but thats what's needed a thick gloop to encapsulate the metal from attack. One side done (the worse by far rear near side).
I was quite impressed when the arch liners was removed as other than the inner edge of the wheel arch, everywhere else was rust free (if we exclude the suspension arms etc. So not really bad at all for an eleven year old car (mid 04). What did look bad was the state of drive shafts out of the diff, my god they look bad, covered in rust is that normal? I'll add it to my list of 'to do' jobs!
The rear wheel arch liners go back in a lot easier than taking them out by the way. I'll try and grab some pics when I do the other side.
  • #94
I have searched everywhere and I cannot find them.
What I will do is put some up over the next few weeks of the finished work and another part that I will be doing.
Painter16
Wolverhampton,West Midlands, England
Sl350 2007
Hi Malcolm just reading this .very good tip as usual and wish to try and do this mod to me sl,only trouble is I carnt see none of your photos ,could you put them on here again please mate thanks
  • #96
I am so sorry they have got lost, such a shame :(:(
  • #98
Not to worry mate,perhaps have a chat about it if I get to meet you at duxford thanks
That would be fine and you can see what I have done to my SL :D:D better weather as well.
