Conor
- Jan 22, 2019
- Location
- London, UK
- 2010 S212 350 CGI // 2004 R230 500
Hi guys,
I set out to repair/re-seal the rear window weather strip on my SL yesterday. What started out as a job following the great guide from Malcolm turned into a bigger rust repair job.
Please note: You should probably read Malcolms guide first as there are a few bits in there, that I won't cover here.
So the steel plate that the trim fixes onto had, some pretty bad bubbling. Here's what I did.
First point is that, Malcolms guide shows doing the work with the roof in a semi open state. This is fine if you are just re-sealing the trim. I found that given the level of work I was doing, it was easier to put the car in to full roof-down mode and just pop up the roof from the boot, as shown.
But here we go.. First look at the damage.
Most of the trim had become un-stuck from the base plate, but the two outer ends were still a bit stuck. I used my recently acquired gasket scraper to cut through the adhesive. It was sharp enough to cut the glue, but not too much that it might sever the strip.
With the weather seal removed, a closer look at the extent of the corrosion.
Apologies for lack of focus .. I really need to check the photos after taking. Arrgh.
Weather strip removed.
