Remote Key Problem
Bighouse
South Coast UK
I have a problem with my spare key - the remote is not working. I have changed the battery but it still deosn't work. I guess it may need to be reprogrammed to the car? If so can I do this myself??;-)
Keys cannot be re programed,maybe it could be repaired depending whats wrong with it
B
Bighouse
South Coast UK
It is a 99 ML320 - The key looks like brand new and fits the locks etc. I was hoping I could press some buttons or something and make it work!
If not can I order a new one using serial numbers or something? If so what information will I need? Cheers.
Maybe it can be taken to pieces and fixed, see Anywebs excellent DIY
You can test the IR part with a digital camera
B
Bighouse
South Coast UK
Just been looking at my key and I dont think it has got Infra Red? I cant see anywhere that the beam would be transmitted from. I wonder would there be some other method for remote CL to work or will it definitely have an IR beam from the key somewhere? I would attach a picture but I dont know how to attach it.
BlackC55
South coast
C43
ML keys can be programmed by a Star but is has to be the key for the car not another key from another car if you see what I mean.
The key is probably faulty. Take it apart and have a look.
Thank you Black for that one, always good to know something new, the guy says that the key fits the locks
lofty
West sussex uk
Remote keys provided with the W168 A class can be reprogrammed to your immobiliser the procedure is in your manual, However keys sold with other cars and/or sold on e-bay cannot be reprogrammed to your car. more info on my site including photo's of the open key. New key blades can however be cut & fitted to existing key fobs
B
Bighouse
South Coast UK
I tried to take my spare key to bits last night but to no avail. I managed to get the battery cover off but the rest of the key looked like a completely sealed peice of plastic and I could not prize it apart. I guess it must come apart as it had a circuit board inside it. I have attached a picture of the type of key - any ideas how they come apart??
B
Bighouse
South Coast UK
I had a look at Anywebs post in the DIY section which was excellent.
I have tried again but I just cant prise my key apart without completely breaking it (I think it must be glued or something). I also tried to do the synchronisation as per the manual but it didnt want to work.
Im going to admit defeat - I can use the key to unlock the car manually (although the alarm goes off until the key is put in the ignition) and it will start the car, so I guess its okay as a spare.
Thanks for your help anyway guys.
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
it may be glued together by the previous owner (assuming there was one) so use a sharp flat blade knife to prize it apart,
it's worthwhile doing and checking
let us know if you suceed
cheers
anyweb
B
Bighouse
South Coast UK
  • #17
I think I may have completely broken my spare key now.
In my wisdom I thought i'd take the battery out and do a continuity test to see if the buttons made a circuit. I removed the key batteries and placed my multimeter on the two battery terminals and set it to continuity testing. When I pressed the key button it showed a complete circuit for a second then it went dead.
I then realised that I probably fried the key circuitry with my multi meter - I think the key works from 6 volts and the multi meter has a 9 volt battery. Damn......
Luckily the key does still start the engine.
Tel: 020 8863 9233
