Remote Locking Broken but Alarm Ok
balanloan
My Dads G reg 190 has a problem
The Scorpion remote opertates the alarm but not the central locking
Can anyone help please
pascal
near Dublin
sl320/1999/3.2
Try this
Hold the button down for 4/5 seconds, EDIT: press fob button briefly twice.
Within 30 sec or less, put key in ingnition, and turn to position 2.
pascal
near Dublin
sl320/1999/3.2
Does the door key opperate the central locking, or just the drivers door.
pascal
near Dublin
sl320/1999/3.2
Oops sorry,
Miss wrote it,
Should have read. Press either fob buttons briefly TWICE and then put key in ignition, and turn to position '2'.
B
balanloan
pardon the ignorance but just to check. Is position 2 the one where the warning lights on the dash light up?
pascal
near Dublin
sl320/1999/3.2
Sure is my friend. but don't turn it to start. LOL
pascal
near Dublin
sl320/1999/3.2
PS. Have you a 1, 2, or 3 button fob.
B
balanloan
The Fob in this case is a Scorpion Fob with only one button is that standard as opposed to a mercedes brand?
pascal
near Dublin
sl320/1999/3.2
Did you try it by double pressing the button.
B
balanloan
Yes but no success. The alarm sets itself but no luck with central locking.
Apparently the problem started after he had a problem with his battery
pascal
near Dublin
sl320/1999/3.2
Its a pretty straight forward system. Two wires from the Scorpion alarm interupt the Central locking control wire (as far as I know).
Pascal.
Will check some other scorpion data I have, later.
In the mean time try the above method again. And if you have a reset key for the alarm, reset that first.
B
balanloan
Thanks. Will dig out the alarm reset info
pascal
near Dublin
sl320/1999/3.2
Better still, If you obtain the number of the alarm (ie 915 or 838 etc), I can fill you in with more info. Scorpion 838 (single CC wire control) was fitted to early MBs
Pascal
