nekomata
Hi everyone
As much as I don't like my first post on a forum being a cry for help, Help! >.<
I've recently bought an N reg C180, but one problem it has is that the remote locking seems to be acting up, and I'm now stuck with an active immobiliser system that I can't de-arm. I still have full access to the vehicle itself (through manual use of the keys), so what I'm hoping to do is deactivate the immobiliser and just lock the car manually until I can fix the remote locking properly.
I'l put below everything that I've noted and tried so far in hope that someone can help with what to try next:
- The key fob is a single button flick out key type
- I've put new MB batteries in the key fob and checked it with a digital camera. Both the red and infrared LEDs are flashing reasonably brightly.
- I've tried prying the key fob case apart to double check the connections, but the case appears to be glued closed. I suspect that the problem isn't in the key fob though as infrared is flashing reasonably brightly.
- I've tried resyncing the key by pressing it twice at the rearview mirror then turning it to position 2 for over 30 seconds. All that happens is that the LEDs flash green and red alternately for about 30s, and the key fob still fails to work.
- I've been trying the key fob pointed at the driver's door handle and at the rearview mirror from both the front and rear. The driver's door lock is of the blanking plate type with nowhere to insert a physical key.
Overall, I'm getting the feeling that car isn't seeing the infrared from the key fob, as I'm not getting any feedback to that effect. Is there anything that should flash at me when I push the key fob button? (Keeping in mind that the key might well be unsynced by this point)
On a related note, is there anywhere in particular that I should be aiming for on the mirror?
Does anyone have any ideas for what I should try from here, either to get the remote locking activate and de-arm the immobiliser (even if just the once), or any other way to reset the immobiliser?
Thanks,
Stu
Thanks,
Stu
