chizzel89
- Feb 27, 2011
- Location
- Pembrokeshire
- Mercedes-Benz C250 Turbodiesel Sport Auto. Estate. 1998. 180,000 mls
I need to bite the bullet and remove the engine and box from my donor car.
I have a two post car lift and a transmission jack and decent quality 3/8" and 1/2" socketry etc with lots and lots of extensions, UJs, wobble extensions etc, so it shouldn't be too difficult?
Should I remove the engine and box together using the front arms of the lift with straps looped on to lift them out or is it safer to remove the trans separately?
I would probably have to put a counter weight on the rear arms of the lift to do this as it says on the lift manual not to load up one side only.
I can't help noticing that the engine and box will need to be tilted back in situ to allow the trans to be unhooked from the engine, which could be hard to control up in the air. I really don't want to damage anything as it was a mission to get the car home.
It is a 1997 C250 TD Elegance saloon with 175k miles, very clean, with good service history. I paid £190 for it on ebay because the owners wife slid it into a lamp post and smashed in a rear door and the sill. Car drove perfectly though and still has tax & MOT. Transmission shifts perfectly (far better than my one) and is quiet, and had the trans fluid & filter done about 15k miles ago with genuine 236.14 MB fluid.
Has anyone seen any good how-to guides on removing the engine and box in a W202?
Cheers
Cheers
