Removing a stuburn injector
si.
Cheshire UK
Srinter LWB 311cdi, Mini Cooper s, Corsa sxi
im having trouble removing a injector and im wondering if there is any body close to chester,cheshire willing to earn a bit of cash to remove it. Its a bit af a emergency too. If there s not any body close could you tell me the best place to buy the remover. Ive hada sliding hammer type remover on it with no joy. The injector has on been in 6wks but had a very small trace of black death around it
We specialised in black death, theres no easy way, it takes time and hours spent in cleaning and soaking, the last one we done ( a forum member ) we spent over 15 hours, but no damage done, its not a quick job!
si.
Cheshire UK
you say it takes time etc and lots of soaking but what do you soak it with??????????????????????
Xtractorfan
S class
Many people use different concoctions to try and soften the black goo.. some have even used ordinary coke ..not the white powder.. alloy wheel cleaner is good, the undiluted acid that car wash guys use, or you can buy it from MB..
kebo57
Lanc's
ml270
Hi you said
"I've had sliding hammer type remover on it with no joy"
I have a slide hammer 3 kgs but it will only fit the ml 270 injectors don't know if yours are the same, also if yours is on a van their might be hight issues getting the tool under the bulkhead depending on which injector is stuck
Kevin
