Could someone please advise me how to remove the drivers side front door panel on a 1994 T124 E220 Estate.
I've got a replacement window regulator and motor to put in (window currently sitting with a 1cm drop).
I've tried the advice from this thread
http://forums.mercedesclub.org.uk/showthread.php?t=8770
http://forums.mercedesclub.org.uk/showpost.php?p=38231&postcount=3
The panel doesn't appear to have any obvious plugs were screws might be hiding behind.
I've just heard one of the bottom clips snap off which appears to hold the tray onto the door.
I've checked the Haynes site and the manual only goes up to 1993.
I'll see if Halfords will let me read it to see if the manual will cover mine.
Are there any other manuals which might have this information ?
guydewdney said:3 screws - - large phillips. keep looking till u find them all.
top edge held with springy clips.
bottom and sides held with pop off clips.
pull bottom out, pull sides out. possibly remove triangle over mirror.
'lift' door panel.
just be careful!
but buy a haynes if i were u.
