removing doors completely
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by Petemac, Nov 27, 2012.
  1. Petemac
    Petemac Senior Member
    153
    Jan 12, 2012
    Inverness
    Your Mercedes:
    merc c250TD 99/2000 150000MILES ON CLOCK GREAT CAR
    i would like to remove all my doors completely will i disconnect battery and wait as i have air bag sensors fitted c250TD 1999
  2. bigasotonuk
    bigasotonuk Senior Member
    5,243
    9
    Nov 14, 2006
    Southampton UK
    Your Mercedes:
    C43/55 AMG 1999 / C230K 1997
    It is always a good idea to disconnect the battery when dealing with car electrics, and if you were to remove the doors and disconnect the door electrics, having the battery disconnected would stop you accidently turning the ignition on whilst the airbags in the front doors were disconnected as this would then put the SRS light on, which would then have to be turned of with STAR or a compatible code reader.
    The best method of disconnecting the front door electrics is by unplugging the two or three multi plugs that can be found in the cable trough in the front footwells, rather than disconnecting the loom from the door and pulling it through the door into the car.
  3. OP
    Petemac
    153
    Jan 12, 2012
    Inverness
    Your Mercedes:
    thanks for quick reply i will take remove battery completely from car cheers
  4. bigtwin
    bigtwin Banned
    964
    Apr 19, 2006
    This is bold. Especially in winter. Think carefully, you may miss them, and fuel efficiency my suffer.
Share This Page
