Removing headlight cover on 2012 C Class
Ductman
Hampshire
C350 CDI Estate/R171 200 SLK/Lotus Exige V6/Lotus Evora GT410 Sport
I noticed, when washing the car yesterday, a pesky little spider has managed to get behind the n/side headlight cover and woven a web. :(
Seems he got what was coming to him as he looks to have been cooked, probably by the headlights, but he's been left hanging there amid a big fluffy web.
Any ideas how difficult a job it might be to remove the cover so I can clean it out please?
Robbostanhill
Dartford, Kent, UK
E270 Estate 2003 and *Her* C220 W203
That looks like an expensive lamp unit !.
Removal of the entire lamp unit and inspection of the way the glass is attached will give some clues.
My old SLK had moisture inside the glass and misting.
Removal showed the glass is held on the lamp by mastic, which if carefully prised gently away the glass came off the lamp housing, cleaning off the old mastic and using fish tank clear glass adhesive mastic reassembly after cleaning was very successful and watertight
Ductman
Ductman
Hampshire
Hmmm, thanks fellas. Think I might leave it a while to see if the web degrades on its own. Knowing my luck, I'd be sure to break something whilst trying to prise it apart.
Ductman
Ductman
Hampshire
Actually, now I think about it, I wonder if I can simply remove the headlight bulb and clean out the inside of the light unit from there???
Maybe I was over complicating things. I'll take a look tomorrow.
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
Exactly that's the best way , use one of those duster type things , the ones with the handle,,
Ductman
Ductman
Hampshire
I'll give it a go tomorrow. :)
EmilysDad
Bury Lancs
ML350
be careful of the silver reflector. If yours is anything like that of my Vauxhall's, you'll only need to give it a hard Paddington stare and it'll come off. :shock::shock:
Ductman
Ductman
Hampshire
I'll do that thanks.
star
Reading
Smart + others :)
Used and airline with a blower to remove dead spider.
