Removing rear seats on w211!!
GurjM
North Herts
Had a spilliage in the boot and need to remove rear seats to clean it up!!!
Please could someone let me know how to remove the rear seats.
Thanks.
If a W211 saloon there are two white catches, one at each side. You need to pull back the seat covering slightly at the base of the seat (below where your thight would be when sitting in the seat). Once you have pulled both catches the base will lift out.
If you have the owners manual it is listed in there.
mstar
bobcat to remove the rear seats in a C class 250 td (1998), does the same apply? i need to insert some new rear seats
