Removing stuck on plates?
ChrisPidwell
E270 CDI Avantgarde W211
How do I remove stuck on number plates. E270 2004?
C
ChrisPidwell
Is there a special adhesive to put the new ones back on with?
Dex
Gloucestershire
www.dphoto.co.uk
Not sure how they are stuck on in your case, but mostly it is the foam double sided tape, to remove put some string one end from top to bottom and slice through the goo......
A warm air gun works well too.
You could ask your MB dealer for some free holders for the plates
Micman
C180K Avantgarde SE
Gently pull them away and try to stick something behind them to help pull them (plastic scraper etc that won't damage anything if it slips). A length of string works as someone already mentioned - use it to slice through the sticky pads.
Once you've got them off, use white spirit to clean up the area and remove all the left over bits of sticky pads.
Places like Halfords sell number plate adhesive strips. They're double sided foam strips - normally use 3 strips, one each end and one in the middle.
Make sure you clean the area well with white spirit on both the car and also on the back of the new number plates to ensure you get a good stick with the new pads. :)
wireman
lancashire
The idea of glue to hold number plates is that you cannot (or should not be able to) remove the plates intact.
This is supposed to prevent plate theft and subsequent legal troubles for the registered owner.
If the foam double sided stuff is holding your plates on dental floss is a very good high tensile string with which to try and remove them, beware that peeling the remains off your plates may pull the yellow or white lamination off with it.
roofless
w124 e220 estate
stick the kettle on till it's near to boiling then pour the hot water on & behind the plate to make the glue soft then pull it off
C
ChrisPidwell
Thanks for all your tips, I'll try it later.
You could always just park over night in Liverpool
Xtractorfan
S class
Carpet tape's pretty strong!
Carpet tape looses it stickiness over a short period and the plate will fall off, use the proper sticky foam pads from halfords or any good Motor factors.. and make sure you mark them out properly before fitting.. measure twice, fit once..
johnboy615
Letchworth, Hertfordshire
2014 c220 Coupe
That's cheap antijam but might take a while to get through 20 of them if you have as few friends as I have!!!!! Heehee!
www.ckinsurance.co.uk
