removing the heater blower motor
icekool
clk/2000/320
hi
just joined, i have a 2000 clk320 that i have had for the last 4 years, bought it of ebay and it's still working!
although the heater blower motor is playing up, worked intermittantly for a while and has now completely stopped.followed a few threads to see the best way to take the motor out to check it over, but i cant find any diagrams on location for removal. if anyone can point me in the right direction i would be grateful.
thanks in anticipation
rob
It drops down under the dash passenger side I think,held with 3 screws
390
m.mycat
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
If you look in the DIY section of the forum, I believe there is a thread regarding replacing the pollen filter/blower motor/regulator in a W202, it is almost exactly the same as a CLK 208.
I
icekool
clk/2000/320
:pthanks for that,Malcolm & Andy, took out the unit tonight cleaned all contacts etc, put it back in and its running like a dream, i have ordered new brushes as they have a lot of wear on them.
regards
rob
marshyboy
wales
clk320
regards
rob
did you order the brushes from mb
gashead
Plymouth
CLK 230K Sport
Sorry to open an old thread but I need to drop my heater blower in my 1998 clk this weekend as its dead. I've looked througt the threads on the removal in the diy section but most of the links are dead or broke. Could anyone paste me a guide on how to remove the motor. I took the facia off under the dash in the passneger footwell but was met with a mass of moulded plastic casings/covers? Do I have to take these of to get the the blower motor? I assume the bushes are worn as power is going through the fuse ok.
Any fools guide would be great.
Top Cat
Milton Keynes
(97) W202 C230 Elegance Estate
Yours will be very similar to this:
http://www.202tech.com/howto/blower.html
Top Cat
Milton Keynes
Top man, thank you very much.
You're welcome.
If you through my posts you will see I had to repair mine last year, but some months later the blower motor itself failed as large segments went open circuit. Definately give the brush replacement a go first though.
