Removing W203 OS wing mirror
Jo&Steve
Crediton, Devon
2003 C320, 2005 L200 Animal
Could anyone tell me the procedure for replacing the glass in a W203 wing mirror?
Steve
I have sent you the details of taking off the cover via Email when that is off you probably unhook the wire spring over the top
With an Email address I can,,only in the next 25 mins otherwise in the morning
jberks
check out the diy section under electrical. Theres a 211 one (by me) about rewiring one - its basically the same and covers strip down. Its based on Malcolm's docs.
Same problem for me - can you post\email me the details?
Many thanks
mi§§§§§§§§§§§§§§§§§§om
Both sent to you,,ask a mod to remove your address if you wish
Raff
East Anglia
W208 CLK200 Kompressor (192HP),VW Touareg V6 TDI
Same problem with W209
Dear all,
Quite recently I have acquired a wing mirror (anti dazzle) for my CLK 240 and to be honest I am puzzled how to replace it. I am really reluctant to break the whole assembly therefore kindly request the above mentioned procedure.
Thank you in advance.
Dear all,
I need an Email address please that you can remove in edit later
Dear Malcolm,
May email is r.n66666666666666666ld.com
I have sent more than you need,,as I never read what I send out.
You can edit out the address now
brover
Sunny Glasgow
c180 sports coupe , c320 avantgarde
could i be a real pest and ask for the mirror removing email too pls malcom , i assume the technique will b similar for both offside and nearside mirrors ?
many thanx
How to change the mirror glass on a W210?(E220CDI-2000)
ala§§§§§§§§§§§§§§§§§§.net
I have sent it,,you can edit out the address
wylywyz
Cork, Ireland
2001 c class c200k, ford puma
Similar problem - need to change o/s wing mirror glass on 2001 w203 c200k. When I fold in mirror there is a plastic cover so I can't see the retaining clip. Help needed please
wylywyz51@gmail.com
wylywyz51@gmail.com
Better late than never I have sent it
learnfast
South west
Sel 420
wing mirror for s420 limosine
please can you email me the relevant info on how to remove wing mirrors for the s420 limosine mank thanks and looking forward to your reply lucusj@hotmail.co.uk
